#154081 - 08/04/200310:07Re: Power source detection problem
[Re: alex25]
tfabris carpal tunnel
The Power Jack is ok.
How do you know this? The symptoms are consistent with a faulty switch.
Of course, as you said, there was another possible reason this would happen, and this is why your player was sent in for repair before. So it could be that, too. I'm just curious why you're so sure the power jack is OK? What did you use to test this?
