Hi,
I've installed the new tRio 1.4 Alpha 5 and can't seem to get it to startup. The alpha 4 version was working fine. I have tried renaming the Alpha 4 directory (as suggested in another post) but still getting the same errors:
STARTED tRio Thu Nov 6 22:59:51 CST 2003
Exception in thread "main" java.lang.SecurityException: class "trio.TRioConfigurable"'s signer information does not match signer information of other classes in the same package
at java.lang.ClassLoader.checkCerts(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
(rest of error not shown)
I'm running on RedHat 9.0 linux, Java 1.4.2.02
I've attached the trio.xml and trio script I use for startup. Also here is the output from the "trio check" command which looks good:
Checking arguments to tRio:
TRIO_HOME = /opt/trio-0.1.4.alpha5
TRIO_CONF = /opt/trio-0.1.4.alpha5/trio.xml
TRIO_RUN = /var/run
TRIO_PID = /var/run/trio.pid
TRIO_CONSOLE = /var/log/trio.log
JAVA_HOME = /opt/j2re1.4.2_02
JAVA_OPTIONS = -Djava.net.preferIPv4Stack=true -Xbootclasspath:/opt/trio-0.1.4.alpha5/lib/pja-mod.jar:/opt/j2re1.4.2_02/lib/rt.jar -Dawt.toolkit=com.eteks.awt.PJAToolkit -Djava.awt.graphicsenv=com.eteks.java2d.PJAGraphicsEnvironment
JAVA = /opt/j2re1.4.2_02/bin/java
JAVA VERSION =
CLASSPATH = /opt/trio-0.1.4.alpha5/lib/commons-beanutils.jar:/opt/trio-0.1.4.alpha5/lib/commons-collections.jar:/opt/trio-0.1.4.alpha5/lib/commons-digester.jar:/opt/trio-0.1.4.alpha5/lib/commons-lang.jar:/opt/trio-0.1.4.alpha5/lib/commons-logging.jar:/opt/trio-0.1.4.alpha5/lib/jrclient.jar:/opt/trio-0.1.4.alpha5/lib/jrcommon.jar:/opt/trio-0.1.4.alpha5/lib/jrutil.jar:/opt/trio-0.1.4.alpha5/lib/pja-mod-old.jar:/opt/trio-0.1.4.alpha5/lib/Strio-applet-0.1.4.jar:/opt/trio-0.1.4.alpha5/lib/trio-0.1.4.jar:/opt/trio-0.1.4.alpha5/lib/trio-applet-0.1.4.jar:/opt/trio-0.1.4.alpha5/lib/xmlrpc.jar
RUN_CMD = /opt/j2re1.4.2_02/bin/java -Djava.net.preferIPv4Stack=true -Xbootclasspath:/opt/trio-0.1.4.alpha5/lib/pja-mod.jar:/opt/j2re1.4.2_02/lib/rt.jar -Dawt.toolkit=com.eteks.awt.PJAToolkit -Djava.awt.graphicsenv=com.eteks.java2d.PJAGraphicsEnvironment -cp /opt/trio-0.1.4.alpha5/lib/commons-beanutils.jar:/opt/trio-0.1.4.alpha5/lib/commons-collections.jar:/opt/trio-0.1.4.alpha5/lib/commons-digester.jar:/opt/trio-0.1.4.alpha5/lib/commons-lang.jar:/opt/trio-0.1.4.alpha5/lib/commons-logging.jar:/opt/trio-0.1.4.alpha5/lib/jrclient.jar:/opt/trio-0.1.4.alpha5/lib/jrcommon.jar:/opt/trio-0.1.4.alpha5/lib/jrutil.jar:/opt/trio-0.1.4.alpha5/lib/pja-mod-old.jar:/opt/trio-0.1.4.alpha5/lib/Strio-applet-0.1.4.jar:/opt/trio-0.1.4.alpha5/lib/trio-0.1.4.jar:/opt/trio-0.1.4.alpha5/lib/trio-applet-0.1.4.jar:/opt/trio-0.1.4.alpha5/lib/xmlrpc.jar trio.TRioServer -c/opt/trio-0.1.4.alpha5/trio.xml
Thanks for any help in advance.
Gary
4253-files.tar.gz (104 downloads)
