#279277 - 24/04/200620:00Re: Hijack v454: Doh! might even work for SaveAux/RestoreSrc & waking
Quote: Mmm.. I've only tested it here by remapping buttons on the Rio Remote. To use the actual extmute line, what voltage should I be applying to it? (+12VDC?)
I suspect my Nokia kit switches the line from open circuit to ground on an incoming call. I am not 100% certain of this as the manual is a bit ambiguous.
