#296009 - 31/03/2007 20:16
Re: Hijack v469: Tuner tweaks
[Re: frog51]
I do think the IF2 bandwidth makes a slight difference (on Radio 1, 2 and 4) the wide setting sounds 'better' - the sound is just a little richer (very slightly, and sometimes I was wondering if I was imagining a change, but it seemed consistent with that setting)
Hope that is of some use
Thanks. The default player setting for that is "Dynamic", which means it auto-adjusts the channel width to match interference conditions. It is believable that "Wide" might be better in some conditions, so you're probably not going insane here.
But "Dynamic" should be best nearly all of the time.
