The alphabetic ordering on the empeg is so that you can jump in the
lists by pressing the letter keys on the remote - ie press 8 two times
and you're on the first song in the list that starts with an 'U'.
If you select the entire playlist it will play in the emplode
'position' column order (unless you've got shuffle on)
IIRC there would be some change as to how omplode ordered tracks
when you dropped a bunch at once into it from the explorer, but I
don't recall exactly what the new behaviour would be.
/Michael
/Michael
