crazy well what mark will try is to drill in the handle from the side and then use a 2mm tap and then lastly bolt the two things together again
what i then do is to cower the flush mounted screw with epoxy and then paint the thing to cower the screw and the small crack
Edited by Boelle (11/06/2008 08:20)
Edit Reason: adding pic
