The datasheet for the WT32i (a great source of info) recommends using a diode when connecting to the RESET pin. So we should do use one there, AFTER the two resistor voltage divider that is also needed.
So.. yeah, the proper way is two resistors as usual, and the output from those to the WT32i then passes through a small diode to guarantee correct direction of current flow.
