#55671 - 08/01/200218:51Re: JEplode 2.0 - Grab Empeg Screen no work
[Re: jwickis]
mschrag pooh-bah
Loc: Richmond, VA
Did you install a version of Java yourself, or are you use the Java that came with the installer for JEmplode? Did you only start getting this error when you made the change I mentioned? The only thing I can think of that might explain this would be attempting to run JEmplode without a version 1.2 or greater Java Runtime Environment....
