dd if=/dev/zero of=/dev/hda3 bs=512 count=1
Get it to ignore the current state:
/empeg/bin/player -i
First you need to have the developer edition of the player software installed - if you don't, go fetch the propoer .upgrade file and apply it.
Then connect to the player through the serial terminal using a program like Hyperterminal, communications parameters are 8 bits, no parity, 1 stop bit, no flow control, 115200bps. When you create the new connection, tell it to Connect using: [direct to your_com_port], then set up the parameters...
With Hyperterminal up and connected, boot the player and press 'q' when prompted (might have to repeat a few times). When you get the command prompt from the player (see attached pic) enter the command
and press enter. It's vital to get this correct (so cut and paste is a good idea) as it will write 512 bytes of 0's to the start of the 3rd partition - you don't want it to write more or elsewhere...
Then enter the second command
to restart the player without it checking for stored state.
Then reboot player and see if it works OK.
HTH,
/Michael
Edit: Oh well, maybe someone else will find it useful. Glad you got it working!
Edited by mtempsch (19/01/2002 07:26)
/Michael
