Loc: San Francisco, CA
I doubt it - if it was a disk drive problem, you wouldn't have gotten as far as you did with the bootup process...
Your drive (I'm assuming that it's a single-drive unit?) is split into seperate partitions; the partition that boot up the empeg is fine, the one holding the music isn't...
...In the case of a disconnected cable, the empeg just doens't boot...
