#143384 - 14/02/2003 15:24 little battery looking image on the screen?
imlikinthebass
theres a little battery looking image on the top right of my MK2 screen. its not there all the time,. jsust wondering what it was. thanks.
#143385 - 14/02/2003 15:25 Re: little battery looking image on the screen? [Re: imlikinthebass]
ricin
Loc: US: CA
See here.
ricin
MkII/080000565
MkIIa/010101253
ricin.io
#143386 - 14/02/2003 15:41 Re: little battery looking image on the screen? [Re: ricin]
Boy, I've got you guys trained well.
#143387 - 14/02/2003 15:45 Re: little battery looking image on the screen? [Re: tfabris]
ricin
Loc: US: CA
Learned from the best.
I was surprised I beat you to it. Were you recharging your batteries, or something?
ricin
MkII/080000565
MkIIa/010101253
ricin.io
#143388 - 14/02/2003 15:46 Re: little battery looking image on the screen? [Re: tfabris]
Oh, and while on the subject of the Battery Icon, note what that FAQ entry says about wiring, and note the other thread here where we discuss confusion regarding the wiring-up of this particular player.
HMMMMMMMM.
#143389 - 14/02/2003 15:48 Re: little battery looking image on the screen? [Re: ricin]
Well, they're not "batteries" in your primitive 21-century sense of the word. But something like that.
#143390 - 15/02/2003 10:16 Re: little battery looking image on the screen? [Re: ricin]
SE_Sport_Driver
Which color is the permanent power wire? Doing a search on "wiring" and "color" didn't show anything. Of course, I could dig through my cabinet and look for the RioCar manual.
#143391 - 15/02/2003 10:38 Re: little battery looking image on the screen? [Re: SE_Sport_Driver]
lockuplever
Loc: Tucson, AZ
Yellow
Steve
#143392 - 16/02/2003 08:56 Re: little battery looking image on the screen? [Re: tfabris]
adavidw
Loc: Utah, USA
And correct me if I'm wrong, but doesn't beta 13 have a known bug where the battery icon always shows up coming out of standy?
-Aaron
#143393 - 16/02/2003 09:50 Re: little battery looking image on the screen? [Re: adavidw]
Not to my knowledge, I never get that. I think others have reported something like that, but I don't know if it was a software bug or not. I don't think we ever got to the bottom of that one.
#143394 - 16/02/2003 12:07 Re: little battery looking image on the screen? [Re: adavidw]
SE_Sport_Driver
Mine only started apearing all the time after one of the HiJack versions - and some others reported the same thing. Mark didn't seem too concerned about it because it didn't look like a software bug to him. I guess I've gotten used to it.
#143395 - 16/02/2003 12:25 Re: little battery looking image on the screen? [Re: SE_Sport_Driver]
thinfourth2
Yeah might be a bug or something as i am getting sick of pulling out the muti meter to measure the damn alternator as i trust the empeg more the car dash as it told me when the last cars electircs died
#143396 - 17/02/2003 05:40 Re: little battery looking image on the screen? [Re: thinfourth2]
muzza
I know my battery if faulty/old. The battery icon comes on, but only after the system has gone temporarily into standby from low voltage. I must do something about it. It's now doing it while waiting in traffic with the engine idling for a while at low revs.
Maybe I need Two batteries, but my system isn't that big. I think the alternator's too small and I cant afford a new one
#143397 - 17/02/2003 08:21 Re: little battery looking image on the screen? [Re: muzza]
Yang
Loc: Raleigh, NC
That sounds like a bad alternator not putting out enough juice. Eventually you will have to buy both alternator and battery if you run the battery down too far. I can sympathize though. I'm on my third alternator, and still have charging issues.
If anyone can help me out, my symptoms are 13 volts constant when the headlights are on, 13 with them off, but <12 when off and I rev the engine or put load on the truck (IE, go up hill, passing breeze, etc..). Once it goes below 12, it stays there until I turn the lights on, and then let off the accellerator.
I've resigned myself to running with my lights on all the time. Mechanic says it's just fine (new factory alternator, new battery). Oh yea.. 1997 Isuzu Rodeo, 60K miles.
#143398 - 17/02/2003 10:56 Re: little battery looking image on the screen? [Re: Yang]
Sounds like a voltage regulator problem, or a wiring/grounding problem somewhere in the system....
#143399 - 17/02/2003 13:02 Re: little battery looking image on the screen? [Re: Yang]
Whitey
Loc: Louisiana, USA
This does sound like a voltage regulation problem. I think you might want to check your ground connection to your alternator.
Edited by Whitey (17/02/2003 13:02)
_______________________________________ former owner...now I'm just another schmuck
#143400 - 17/02/2003 16:03 Re: little battery looking image on the screen? [Re: Whitey]
Yang
Loc: Raleigh, NC
The alternator contains the voltage regulator, so I think I'll figure out where the connector for the ground actually goes and check there.
#143401 - 17/02/2003 16:31 Re: little battery looking image on the screen? [Re: SE_Sport_Driver]
TheAmigo
I see the battery icon when I restart my car after getting gas.
My stock CD player would lose power long enough during the ignition process that it'd have to re-spin the CD and take a few seconds to pick up where it left off. The empeg just pauses for a second (blank screen and silence) then picks up in about 2 seconds with the battery icon showing briefly. I'm impressed that it doesn't reboot.
--The Amigo
#143402 - 17/02/2003 16:45 Re: little battery looking image on the screen? [Re: TheAmigo]
mandiola
**TRY THIS AT YOUR OWN RISK** I was having problems with the battery icon coming on and then the empeg shutting off. I asked around and got some advise to run the power wire off of my fuse box. I decided to try it and ran it from the heater fuse. The problem was that the oem wire wasn't thick enough to carry enough power to supply both my sony player and the empeg. This *may* work for you.
-Greg
#143403 - 17/02/2003 16:52 Re: little battery looking image on the screen? [Re: mandiola]
TheAmigo
What I meant to imply in my last post is that for me, the battery icon seems appropriate. While starting the car, it's expected that you lose power to accessories.
--The Amigo
#143404 - 17/02/2003 16:59 Re: little battery looking image on the screen? [Re: TheAmigo]
mandiola
Yeah that was for muzza and anyone else having problems with the battery icon... just something to try. Most cars do loose power when you start the car.
-Greg
