Page 2 of 3 < 1 2 3 >
#150364 - 27/03/2003 16:14 Re: Bugs? *What* bugs? [Re: Roger]
The Developer Info Section Gnomes need to see this one...
Ooooo.... I'll bet you could put an ;@AC in front of that (if using hijack) and have it only happen on AC power... cool...
Question: Does it completely prevent spindown, or do the drive still spin down when it goes into standby?
#150365 - 27/03/2003 16:30 Re: Bugs? *What* bugs? [Re: tfabris]
Dunno.
#150366 - 27/03/2003 16:48 Re: Bugs? *What* bugs? [Re: Roger]
Easy enough to find out, I suppose. Let us know how it goes, Brad.
#150367 - 27/03/2003 17:36 Re: Bugs? *What* bugs? [Re: tfabris]
SE_Sport_Driver
Will do. (I never used the @Home thing, so I'm reading up on that now.) Thanks Roger and Tony.
- VERY excited for 2.00final!
#150368 - 27/03/2003 17:48 Re: Bugs? *What* bugs? [Re: Roger]
And if you ARE using hijack, you must also add this:
[hijack]
spindown_seconds=0
#150369 - 27/03/2003 18:09 Re: Bugs? *What* bugs? [Re: tfabris]
SE_Sport_Driver
How does this look? (Going for the drives to always spindown, except for @WORK)
[Options]
Name=Brad's empeg
;@HOME spindown=1
;@WORK spindown=0
spindown=1
[hijack]
;@WORK spindown_seconds=0
spindown_seconds=30
Edited by SE_Sport_Driver (27/03/2003 18:12)
#150370 - 27/03/2003 18:12 Re: Bugs? *What* bugs? [Re: SE_Sport_Driver]
Simplify it a bit:
EDIT: FIXED An ERROR!!
[Options]
Name=Brad's empeg
;@WORK spindown=0
[hijack]
OF course, there's also ;@AC and ;@DC, which may or may not be more appropriate than ;@WORK in your case.
Edited by mlord (27/03/2003 18:13)
#150371 - 27/03/2003 18:15 Re: Bugs? *What* bugs? [Re: mlord]
SE_Sport_Driver
So if the player isn't set "@WORK" when it boots, it will skip my entries and go for the defaults (1 for spindown and 30 for timeout)?
#150372 - 27/03/2003 19:06 Re: Bugs? *What* bugs? [Re: SE_Sport_Driver]
That's the idea!
#150373 - 27/03/2003 20:35 Re: Bugs? *What* bugs? [Re: peter]
StigOE
Ah, have to check this out when I get home next week...Thanks.
Stig
#150374 - 27/03/2003 20:46 Re: Bugs? *What* bugs? [Re: mlord]
I've found, and I don't know if this is a feature or a misbug, that you can successfully combine the AC/DC qualifiers with the WORK/HOME qualifiers.
#150375 - 27/03/2003 20:57 Re: Bugs? *What* bugs? [Re: wfaulk]
That would be a documented feature, but it only works in one order: the AC/DC must be to the left of the HOME/WORK.
#150376 - 27/03/2003 21:06 Re: Bugs? *What* bugs? [Re: mlord]
So it is. I got lucky when I tried it, I guess.
#150377 - 27/03/2003 22:11 Re: Bugs? *What* bugs? [Re: rob]
JrFaust
Loc: New Richmond, WI
So we fixed about a dozen bugs, and I'd say that about does it for 2.0. If RC3 checks out OK then there will be a public release soon.
Your player has gotten better at playing MP3's! (2)
/shout WOOT!!!
/em does a dance of joy!!!
Drive fast, Play it loud!!!
20GB Original Blue Lens MKIIa Rio SN 030102760, Blue Buttons.
20GB Original Green Lens MKIIa Rio SN 040103268 Grey Buttons.
#150378 - 27/03/2003 23:33 Re: Bugs? *What* bugs? [Re: Roger]
In config.ini:
[options]
spindown=0
I searched and only found this mentioned in one other post other than this one. Perhaps one for the FAQ? Is there a list of non-Hijack config.ini options anywhere? I can't seem to find one.
#150379 - 27/03/2003 23:36 Re: Bugs? *What* bugs? [Re: Shonky]
OK, replying to my own post again. But I did find a list of options in the Developer section on Riocar.org.
But no mention of the spindown=0 option
Perhaps this developer info could be integrated into the FAQ in a separate section? Tony?
#150380 - 28/03/2003 05:01 Re: Bugs? *What* bugs? [Re: Shonky]
Right. Hence my earlier comment about the Developer Info Section Gnomes.
The FAQ entry about config.ini provides a direct link to the section in Developer Info. I don't see how it could get any more clear than that?
#150381 - 28/03/2003 05:09 Re: Bugs? *What* bugs? [Re: tfabris]
From that FAQ entry:
Finally, note that the player software has a 4096-byte limit. This means that if your config.ini is longer than 4096 bytes, it will not be read correctly (actually it will only read the bytes after the 4096 mark). So keep your config.ini as small as possible.
There's no such limitation. The only limit is that individual lines can be no longer than 1,023 bytes.
#150382 - 28/03/2003 05:11 Re: Bugs? *What* bugs? [Re: tfabris]
Mmmmkay missed the gnomes bit. Also when you've read the FAQ a fair bit already you tend to gloss over some things.
Not trying to argue or be difficult, but the developer section isn't searchable. i.e. I have actually searched the FAQ for spindown before but even if it was in the developer section, it still wouldn't have shown up.
Wouldn't it be better to have it all in one? Apart from the extra work for the FAQ guy though
#150383 - 28/03/2003 05:14 Re: Bugs? *What* bugs? [Re: peter]
Okay, I'm editing the entry.
Mark Lord seemed pretty certain about the modulo-4096 thing when he reported it. So I'm going to let you two fight it out.
Question: Then why does the player software start screwing up really bad after a bunch of entries get added because of the beta-11 favorite-visuals-doubling bug? None of those have a single line longer than 1024.
Unless by "line" you mean "section"...
#150384 - 28/03/2003 05:28 Re: Bugs? *What* bugs? [Re: tfabris]
Well, I think we all agree that the bug is no longer there. I think Mark Lord and I have agreed to disagree on whether it was ever there...
#150385 - 28/03/2003 06:43 Re: Bugs? *What* bugs? [Re: peter]
Which release of player software fixed the documented and observed 4096 byte limitation?
#150386 - 28/03/2003 06:49 Re: Bugs? *What* bugs? [Re: peter]
21/02/02 12:31 PM
Hijack v201 Released
This version features:
# Hijack now correctly handles LARGE config.ini files.
But please note that the player software does not handle them well:
it will read only the tail end of the file, modulo 4096. This means that
if your config.ini file is 4097 bytes long, the player software will read
only the final byte. This happens whether or not you have Hijack
installed. I suppose I might try to add code to nuke all of the non-player
stuff from the file to help out the player, but even that would not be
simple because the player checks the filesize before computing how much to
read. Ugly bug.
#150387 - 28/03/2003 07:45 Re: Bugs? *What* bugs? [Re: mlord]
The oldest "v2" version I can find is 1.10-alpha3, which does not exhibit the bug. The CVS history on that file goes back to car v1 beta 8, and shows no significant changes. If this bug ever existed, it was fixed before v1.00 beta 8, which was probably released in early 2000, although that was before the Announcements forum was invented, so it's difficult to tell.
#150388 - 28/03/2003 14:51 Re: Bugs? *What* bugs? [Re: peter]
Mmm.. I'll have to retest. Might've been something in Hijack, but at the time I believe I tried it with a stock Empeg kernel as well. More when I know more..
#150389 - 28/03/2003 18:38 Re: Bugs? *What* bugs? [Re: peter]
loren
i noticed a bug... you spelled "synchronising" wrong
|| loren ||
#150390 - 28/03/2003 21:04 Re: Bugs? *What* bugs? [Re: loren]
Happy Birthday tonyc
Ah, that joke keeps getting better with age!
#150391 - 29/03/2003 09:04 Re: Bugs? *What* bugs? [Re: peter]
Mm.. Okay, here is the file access pattern when the player reads config.ini at startup:
HIJACK: read(config.ini): PID=9(player), pos=8192/8268, count=76
HIJACK: read(config.ini): PID=9(player), pos=0/8268, count=4096
HIJACK: read(config.ini): PID=9(player), pos=4096/8268, count=4096
HIJACK: read(config.ini): PID=9(player), pos=8192/8268, count=4096
HIJACK: read(config.ini): PID=9(player), pos=8268/8268, count=4096
The filesize in this case is 8268, "pos" is the starting offset for the read, and count is how many bytes were requested. I didn't trace lseek(), but it looks like something has done an lseek(filesize modulo 4096) before doing the first read.
It's that first read of (filesize modulo 4096) that is confusing Hijack into thinking that only the end of the file was being read. Why is the player doing that? Or is it some quirk in libc, trying to trigger a readahead of the whole file or something?
I suppose I'll have to make hijack more clever or something on this. Tricky..
#150392 - 29/03/2003 09:26 Re: Bugs? *What* bugs? [Re: mlord]
Okay, based on this info, I've modified Hijack to cope with the strange access pattern, and v322 will be out shortly.
#150393 - 29/03/2003 10:25 Re: Bugs? *What* bugs? [Re: mlord]
I agree, that's certainly very odd. The player, though, just opens the file fully buffered with fopen and reads it with fgets: it must be glibc's buffering that's doing something strange with the underlying fd.
