#20112 - 11/10/2000 19:53 audiocatalyst
Terminator
Loc: Dallas, TX
I having a problem with audiocatalyst. On every cd i rip and encode, the first track has some skipping on it. It has just started this behavior recently. Any ideas on how to fix it or what could be causing it?
Sean
Empeg 12 gig green 080000078
#20113 - 11/10/2000 21:16 Re: audiocatalyst [Re: Terminator]
bootsy
Loc: Seattle, WA. USA
Does the skipping occur at the beginning of the first track? This is just a shot in the dark, but does Audiocatalyst have a "spin up disc before ripping" option?
Brian H. Johnson
MK2 36GB Blue
"Born to Lose..."
Brian H. Johnson
MK2 36GB Blue, currently on life support
"RIP RCR..."
#20114 - 11/10/2000 21:36 Re: audiocatalyst [Re: bootsy]
Terminator
Loc: Dallas, TX
I already have that checked. I fixed it by turning on sync data transfer in the control panel under my plextor cdrom. Thanks for the help.
Sean
#20115 - 12/10/2000 02:06 Re: audiocatalyst [Re: Terminator]
Get Exact Audio Copy for Windows, or cdparanoia for Linux. It's the only way to be sure...
#20116 - 17/10/2000 09:05 Re: audiocatalyst [Re: Terminator]
Terminator
Loc: Dallas, TX
The sync data transfer box didn't fix it, but reinstalling ASPI did.
Sean
#20117 - 17/10/2000 09:09 Re: audiocatalyst [Re: peter]
Terminator
Loc: Dallas, TX
I have EAC, I usually only use it on its that are scratched up a bit. If the cd is in good shape, I use audiograbber now.
Sean
#20118 - 18/10/2000 07:12 Re: audiocatalyst [Re: Terminator]
smu
Loc: Germany (Ruhrgebiet)
Hi Sean.
With a drive that supports error detection (C2), EAC should not be any slower or otherwise minor to Audiograbber, but way superior when it comes to making exact grabs on scratched discs. Effectively, EAC 0.9pb7 is about 2-3% slower than AudioGrabber on a new disc, and about 50% slower on a severely scratched one. However, AudioGrabber produces different results on each run on that scratched disc, while EAC always produces the same result. While I can live with the slowdown on new discs, I certainly can´t live with damaged grabs like AG produces on scratched discs.
cu,
sven
#20119 - 18/10/2000 08:37 Re: audiocatalyst [Re: smu]
Terminator
Loc: Dallas, TX
I have a plextor 8/4/32 drive. Its been very reliable for DAE so far. Maybe there is some setting in EAC that I have set wrong that could be causing it to go much slower than normal. I'll take a second look at the settings.
Sean
#20120 - 18/10/2000 14:16 Re: audiocatalyst [Re: smu]
Another alternative is to "unscratch" the disk. Take a look here for a link to how to do it.
