#237505 - 13/10/2004 11:40 Awww crap! Is my HD toast?
Flawed
SO I was doing a sync last night, computer locked up. Couldn't wait any longer so I unplugged the empeg and started home. Obvioulsy I got the "Buliding Music Databases" thing. Only it never finished. Now, when I connect to it via hyperterm to see what's up it boots pretty normally at first, then gets all wonky.
Here's the normal portion with me trying to enter the shell prompt at the end:
Copying kernel...ce ide0(3,68)): e
Calling linux kernel... blocks not in dataz
Uncompressing Linux..................................... done, booting the kerne - block = 3361739355, count = 1ext2_free_blocks: Freeing blocks no
Remounting f
l.sy
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v394 (mark@rtr.ca) (gcc version 2.: ext2_free_blocks: bit already cleared for b
Remounting filesyst
95.3 20010315 (release)) #2 Fri Jun 4 16:34:01 EDT 200471(device ide0
EXT2-fs error (device ide0(3,68)): ext2_
Processor: Intel StrongARM-1100 revis
Calibrating delay loop... 207.67 BogoMIPSn dataz
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)unt = 1
Rem
Remounting filesystem read-only
Dentry hash table entries: 2048 (order 2, 16k)device ide0(3,68)): ext2_free_blocks: Freeing
loc
one - b
Page cache hash table entries: 4096 (order 2, 16k)t2_free_bloc
one - blo
Starting kswapd v 1.5
EXT2-fs error (
SA1100 serial driver version 4.27 with no serial options enableding filesystem read-only
EXT2-fs
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART= 1 blocks not in dataz
Remountin
EXT2-fs error (device ide0(3,68)): ext2_fre
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTem read-only
EXT2-fs erro
empeg audio-in initialised, CS4231A revision a0 blocks not in dataz
Remount
one - block = 3064918202, count = 1: ex
empeg usb initialised, PDIUSBD12 id 1012g filesystem read-only
empeg state support initialised 0089/88c1 (save to d0005400).cks: Freeing blocks not in dataz
Remountin
empeg RDS driver initialised
one -
empeg power-pic driver initialised (first boot): Freeing blocks
EXT2-fs erro
hda: IC25T048ATDA05-0, 45780MB w/1806kB Cache, CHS=5836/255/63dataz
hdb: IC25T048ATDA05-0, 45780MB w/1806kB Cache, CHS=5836/255/63ext2_free_blocks: Freeing blocks not in datazlesystem read-onl
smc chip id/revision 0x3349 count = 1s not in dataz
one
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:tem read-only
Mounting proc
Starting player
Timezone: /usr/share/zoneinfo/Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
q
And here's where it gets ugly:
one - block = 875417976, count = 1 ext2_free_blocks: Freeing blocks
Remounting filesystem read-onlyly_free_blocks: Freeing blocks
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazaz
one - b
one - block = 852251694, count = 1): ext2_free_blocks: Freeing block
Remounting filesystem read-onlyonly_free_blocks: Freeing block
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazataz
one -
one - block = 518434327, count = 1): ext2_free_blocks: Freeing block
one - b
one - block = 369219712, count = 18)): ext2_free_blocks: Freeing blo
Remounting filesystem read-onlyd-only
one - block = 1178949070, count = 1cks not in dataz
o
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazfilesystem read-only
one - block = 1719701543, count = 1cks not in dataz
o
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks noemounting filesystem read-only
one - block = 3361739355, count = 1ext2_free_blocks: Freeing blocks no
EXT2-fs warning (device ide0(3,68)): ext2_free_blocks: bit already cleared for b
E
lock 5367171(device ide0
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freelesystem read-onlyly
o
one - block = 941671164, count = 1 ext2_free_blocks: Freeing block
R
E
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in dataz44: rw=0, want=707846753, limit=46773247m read-only
o
one - block = 3821292659, count = 11439636896 sector=1415693504 si
Rem
EXT
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazd failure, inode=4240, bloting filesystem read-only
loc
one - block = 1414253936, count = 1(device ide0(3,68)): ext2_free_bloc
Remounting filesystem read-onlyto access beyond end of device
Remounting filesystem read-only blksize=1024 blocknr=-207519
one - block = 2983795291, count = 1: ext2_free_blocks: Freeing blocks
EXT2-fs error (de
ck=-2075190014
one - block = 3064918202, count = 1: ext2_free_blocks: Freeing blocks
Remounting filesystem read-only of device
R
Remounting filesystem read-onlyocknr=-680818825 sector=-1361
one - block = 2726208061, count = 1: ext2_free_blocks: Freeing blocks
dev 03:44
one - block = 3926023841, count = 1s not in datazor b
EXT2-fs error
one
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazlesystem read-only in dataz
one - block = 1005629655, count = 1s not in dataz99, count = 1
Remounting filesystem read-only of deviceesystem read-only
one
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks noounting filesystem read-onlyly
one - block = 2810481692, count = 1: ext2_free_blocks: Freeing blocks
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in dataz40, blo
one - block = 1302057062, count = 1: ext2_free_blocks: Freeing blocks
Remounting filesystem read-onlypt to access beyo
ck=-1118000724
EXT
one - block = 2791901850, count = 1locks not in dataz access beyond en
03:44: rw=0,
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazg filesystem read-onlyknr=-1066760921 sector=-2133521
one - block = 2537640674, count = 1locks not in dataz
R
Remounting filesystem read-only68)): trunc_indirect: Read fail
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks noemounting filesystem read-onlyck=-1066760921
one - block = 2308679593, count = 1ext2_free_blocks: Freeing blocks no
03:44: rw
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazev 03:44 blksize=
Remounting filesystem read-only552681558 size=1024 count=1
one
one - block = 3997813456, count = 1ext2_free_blocks: Freeing blocks no
Remounting filesystem read-onlye ide0(3,68)): ext2_free_blocks
EXT2-fs error (
one - block = 2345214658, count = 1Read failure, in
one - block = 2592444272, count = 1ystem read-only
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in dataz68)): ext2_free_blocks: bit
one - block = 3197617516, count = 1ext2_free_blocks
one - block = 3605089355, count = 1ystem read-onlyock 9857123
one - block = 3892143504, count = 1locks not in dataz
Unc
one - block = 3474766030, count = 1d-only........... done, booting the
Remounting filesystem read-only68)): ext2_free_blocks: Freeing
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazmark@rtr.ca) (gcc v
one - block = 1569829695, count = 1eady cleared for b
one - block = 563119510, count = 1ad-only (release)) #2 Fri Jun 4 16
Remounting filesystem read-only3,68)): ext2_free_blocks: Freei
empeg-car player (har
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazing filesystem read-only
Command line
one - block = 2272412640, count = 1 blocks not in dataz
Remounting filesystem read-only/16M available (980k code, 20k
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazing filesystem read-onlyentry hash table entries: 2048
one - block = 1431569949, count = 1 blocks not in datazble entries: 16
loc
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks notR
E
one - block = 2083294330, count = 1ext2_free_blocks: Freeing blocks no
R
Remounting filesystem read-onlyrq = 17) is a SA1100 UART
E
one - block = 113490097, count = 1 ext2_free_blocks: Freeing blocks
one - block = 1976702481, count = 1cks not in dataz
Remounting filesystem read-onlynel button initialised.
o
empeg state
one - block = 3374994519, count = 1cks not in dataz
Remounting filesystem read-onlyialised
o
E
one - block = 1554333034, count = 1t2_free_blocks: Freeing blocks not
Remounting filesystem read-onlypeg-flash driver initialized
E
smc9194.c:v
Remounting filesystem read-onlyerik@vt.edu)
EXT
one - block = 985250376, count = 12_free_blocks: Freeing blocks not
one - block = 1936942811, count = 1ounting second music partit
one - block = 1184041996, count = 1onlynting first music partition rea
Remounting filesystem read-only)): ext2_free_blocks: Freeing b
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in dataz' now to go into
one - block = 3491519999, count = 1nds To Comply...az
one - block = 731036389, count = 1-only
St
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in dataztercepting config.i
one - block = 908586269, count = 1hijack: removed menu entry
one - block = 2494536869, count = 1onlyly
R
q
EXT2-fs warn
E
one - block = 932143636, count = 1blocks not in dataz_free_blocks: b
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazing filesystem read-onlyxt2_free_blocks: bit already cl
one - block = 3101187615, count = 1 blocks not in dataz
lock
Remounting filesystem read-onlyning (device ide0(3,68)): ext2_
lock 9849579
one - block = 2517365469, count = 1cks not in datazXT2-fs warning (dev
Remounting filesystem read-onlys: bit already cleared for bi
o
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazfilesystem read-only_
one - block = 2301139468, count = 1cks not in dataz
Un
one - blo
Remounting filesystem read-onlyone - block = 3054378371, cou
o
one - block = 443530523, count = 1ocks not in dataz
one - b
one - block = 2368025062, cou
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks notRemounting filesystem read-only
one - block = 71274286, count = 1locks not in datazaz
Remounting filesystem read-onlyonlyET4.0
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazing filesystem read-onlyly84 bhash 16384)
one - block = 2750489638, count = 1 blocks not in datazaztli)
one - block = 3678768334, count = 1 blocks not in datazaz
Remounting filesystem read-onlyonlyrq = 17) is a SA1100 UART
one - block = 3487419045, count = 1ext2_free_blocks: Freeing blocks no
Remounting filesystem read-onlyempeg dsp initiali
Remounting f
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in dataz8)): ext2_free_bl
Remounting filesystem read-onlyzel button initialised.
o
one - block = 2775364618, count = 1ext2_free_blocks: Freeing blocks no
e
Remounting f
Remounting filesystem read-onlyzalised
o
one - block = 351319203, count = 1 ext2_free_blocks: Freeing blocks
hdb: hdb1 < hdb5
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazstem found at b
R
RAMDISK: Loadin
E
one - block = 604999313, count = 1 ext2_free_blocks: Freeing blocks
Remounting filesystem read-onlylyFS: Mounted root (ext2 filesy
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in dataz,68)): ext2_free_bl
Pres
one - block = 1768529019, count = 1: ext2_free_blocks: Freeing blocks
Remounting f
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in dataz8)): ext2_free_bloc
Freeing
one - block = 298976059, count = 1): ext2_free_blocks: Freeing block
Remounting filesystem read-onlylyis is a develope
Remounting filesystem read-onlyly04/01.
EXT2-fs error (device ide0(3,68)): ext2_free_blocks: Freeing blocks not in datazaz1002).
q
EXT2-fs w
one - block = 2187426529, count = 1: ext2_free_blocks: Freeing blocks
attempt to access beyond end of deviceck = 4237664256, count = 1locks not in
03:44: rw=0, want=707846753, limit=46773247m read-only
E
dev 03:44 blksize=1024 blocknr=-1439636896 sector=1415693504 size=1024 count=1zg filesystem read-onlyext2_free_blocks: bit already c
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=4240, bloting filesystem read-onlying (device ide0(3,68)): ext2
E
ck=-14396368962_free_blocks:
Remounting filesystem read-onlylesystem read-only
ck=-1463263210ot in datazaz
Remounting filesystem read-onlysystem read-onlyEXT2-fs warning
attempt to access beyond end of device, count = 1 1ext2_free_blocks: Freeing
03:44: rw=0, want=643454985, limit=46773247
lo
EXT2-fs error (
dev 03:44 blksize=1024 blocknr=-1504028664 sector=1286909968 size=1024 count=1ed fo
one - block
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, ting filesystem read-onlyly
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=4240, blo 1cks not in dataz
ck=-2075190014cou
o
EXT2-fs
Remounting filesystem read-onlyfree_blocks: Freeing blocks not
attempt to access beyond end of deviceerror (device ide0(3,
EXT2-fs error (d
03:44: rw=0, want=1466664824, limit=46773247= 1cks not in dataz
R
Remou
dev 03:44 blksize=1024 blocknr=-680818825 sector=-1361637650 size=1024 count=1 ide0(3,68)): ext2_free_blocks: Freeing blocks noemounting filesystem read-onl
dev 03:44 blksize=1024 blocknr=-1447305577 sector=1400356142 size=1024 count=1dy cleared for b
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=4240, bloext2_free_blocks: Freeing blocks not in dataz
EXT2-fs er
ck=-14473055770(3,68)): ext2
Remounting filesystem read-only039023199, count = 1
Remo
attempt to access beyond end of deviceesystem read-only
one - block = 1623
03:44: rw=0, want=1519212955, limit=46773247 ext2_free_blocks: Freesystem read-onlyly
03:44: rw=0, want=1993535096, limit=46773247mounting filesystem read-only
dev 03:44 blksize=1024 blocknr=-153948553 sector=-307897106 size=1024 count=1blocks no
E
EXT2
Rem
EXT
one
ck=-1066760921
03:44: rw=0, want=1760015302, limit=46773247
dev 03:44 blksize=1024 blocknr=1760015301 sector=-774936694 size=1024 count=1
ck=1760015301
03:44: rw=0, want=1871142870, limit=46773247
dev 03:44 blksize=1024 blocknr=-276340779 sector=-552681558 size=1024 count=1
ck=-276340779
03:44: rw=0, want=1354840137, limit=46773247
dev 03:44 blksize=1024 blocknr=1354840136 sector=-1585287024 size=1024 count=1
ck=1354840136
lock 9857123
Got any suggestions? AFter that last bit o crap, the HD's stop making any noise.
Sigh...
#237506 - 13/10/2004 11:44 Re: Awww crap! Is my HD toast? [Re: Flawed]
Cute... Well, it looks like you caused some damage to the various filesystems. As soon as you can, hit CTRL-C to break the player application. This will be as soon as you see it try to remount the music partitions. At that point, turn on your swap and try to check the disks by hand.
#237507 - 13/10/2004 12:52 Re: Awww crap! Is my HD toast? [Re: Flawed]
time
Loc: Southwest
Good news is that if the drive is toast, today at Slick Deals.NET there are 7200rpm 60G Hatachi drives for $133 shipped. Seems like a good deal.
#237508 - 13/10/2004 12:59 Re: Awww crap! Is my HD toast? [Re: pgrzelak]
Flawed
Thanks Paul! Worked perfectly! Took a while and found many errors but it's working now!
Thanks again!
#237509 - 13/10/2004 13:26 Re: Awww crap! Is my HD toast? [Re: Flawed]
Cool!
