#327534 - 13/11/2009 12:34 Bad Pump Woes :(
kendrick
I am trying to install a new hard drive into my empeg because the system says NO HARD DISK FOUND with the original drive.
However when I am applying the builder upgrade it gets to SELECTING PUMP and eventually comes back with a bad pump response.
I have viewed the bad pump FAQ, checked the cable connections and also tried 3 different hard drives.
Below is the log of what happens when I plug up the drive. Any ideas?
I have tried a 10GB, 30GB, and an 80GB drive.
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101950) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0180
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xabaa
ide_data_test: wrote 0x5555 read 0x5555
ide_data_test: wrote 0x5555 read 0x55d5
Dead temp.sensor, status=0x00
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:9
e
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...•Ô•…¹¹½Ñ½Á•¹É½½Ñ‘•Ù¥•ÁÍéÁÕ)5 Kernel panic: V
FS: Unable to mount root fs on 03:05
#327536 - 13/11/2009 15:10 Re: Bad Pump Woes :( [Re: kendrick]
Let's see. The FAQ entry for pump errors lists a several possible causes:
1. Corrupted ".upgrade" file.
Which upgrade file are you using?
2. Serial port/cable problems.
Your boot log looks fine so I'm guessing you have a working serial cable with which to retrieve that boot log. However, it doesn't completely rule out an intermittent serial cable problem, or perhaps a problem with sending data but not a problem receiving it.
3. Bad disk drive.
You have ruled that out by trying three disk drives.
4. Other hard disk troubles.
Aha, now here's the likely culprit. You say you checked the cable connections, but how certain are you that the IDE header is good and isn't getting the cracking joints problem? Or perhaps theres a problem with the drive interface electronics. I'm guessing it's one of those. This theory is supported by three pieces of information:
- You'd had NO HARD DISK FOUND errors to begin with.
- You have the same trouble no matter which disk you plug in.
- Your boot log indicates a bitwise error in its IDE tests:
