#45632 - 08/11/2001 21:25
Hijack v45: new button state tracker
Okay, the v4x series of my patches all seem to have buggy button state tracking in various scenarios, so I've rewritten my button state tracker to clean up the logic and eliminate (all?) the quirks.
-- replaced ugly button tracker with less ugly code
-- fixed the & and ' characters in the font (they were reversed)
-- prevent overflow on input in the calculator
-- new Reboot option (with confirmation), for Tony
-- press and continue to hold knob to cycle through input-sources at 1sec intervals
This version (v45) looks good so far for me, much better than its recent predecessors.
Give it whirl, and let me know if you find any undocumented features.
http://rtr.ca/empeg/
Edited by mlord (08/11/2001 21:25)
#45633 - 08/11/2001 21:29
Re: Hijack v45: new button state tracker
Ooops.. no bugs (yet), but I think I forgot to remove a printk() from the button handler.
Expect v46 in about 3 minutes or so..
#45634 - 08/11/2001 21:56
Heh, thanks for the reboot feature. I'm grabbing 46 now.
I'm about to head off on a really long drive in the morning. Hope 46 is stable.
#45635 - 08/11/2001 22:02
Okay, the reboot feature rocks. Also, the hold-knob thing with switching to radio worked perfectly the first time I tried it. Did you have to do something special or was I wrong about the behavior of the Source button?
#45636 - 08/11/2001 22:53
I did special stuff to make it work.
There's STILL an excess printk() spewing to the serial port on every button press, but mostly harmless. I'm now tracking down a very strange issue with the 100% setting on the blanker -- fails to fire cuz one byte is different on the screen (but it shouldn't be different.. ) most strange. Maybe a caching issue? Everything else looks really good now.
#45637 - 08/11/2001 23:19
Okay, found it. Compiler bug, I think.
(screen blanker failing at 100% sensitivity due to a phantom screen byte "differing").
I was declaring a static 2048 byte screen buffer on the same line as a 1-byte variable, and the compiler just aligned them next to each other, giving a horribly misaligned 2048 byte buffer. Funny thing is, this results in memcpy not working correctly on the buffer, and neither does a hand coded for-loop doing the same copy. ARrrrggg.
Anyway, I'll hand tweak it so it works again.
UPDATE:
The scary part of this, was that the "static" local variable moved around in memory on successive calls.. static vars ain't supposed to do that! So I moved it to outside of the function, and now it stays put, and is correctly aligned as a bonus.
v47 will follow
Edited by mlord (08/11/2001 23:50)
#45638 - 08/11/2001 23:55
Hmmm ....
I think I've been hijacked permanently. I just downloaded v47.voladj.hijack.v200b3.mk1.zImage and can't seem to get out of it. Every five seconds or so the screen flicks back to the visual (briefly) and then repaints the hijack menu.
#45639 - 09/11/2001 07:34
[Re: xavyer]
>I think I've been hijacked permanently. I just downloaded v47and can't seem to get out of it.
I'm gonna need more information to go on than just that -- it works perfectly for me.
Which model of player; what buttons did you press; what did you do inside the menu; how did you exit from it; .. etc.
UPDATE:
Okay, I got it to happen here now..
For the morbidly curious, this requires a Kenwood remote. Just hit CD CD CD and watch!
v48 will be out in a few minutes with this bug squashed.
Everything else still looks and works great! (repeat 100 times..  )
Edited by mlord (09/11/2001 07:44)
#45640 - 09/11/2001 08:16
Hijack v48: Looking good..
Okay, after a crazy evening rewriting the button tracker, and then fixing the odd bit here and there, we're up to v48 now. Here's most of what's different since v45:
--- fixed the CD/CD/CD entry sequence to allow exiting again!
--- fixed a compiler issue with 100% sensitivity on the screen blanker
--- removed some stray debugging output (printk calls)
I'm now pretty happy with it; which is good, since I'll be away travelling a lot in the near future.
Thanks (!) to "andy", there's a tuner module on its way to me, and thanks to my spouse there's a Mk2a also on the way (her car stereo just died today). So I guess we ain't done with new features here yet!
#45641 - 09/11/2001 09:39
Thank you! I'll download v48 in just a moment.
#45642 - 09/11/2001 10:54
Re: Hijack v48: Looking good..
Ok, Here is a great idea. Could an alarm clock implemented in HiJack 49 or 50? ;) That would be simply amazing!!!
#45643 - 09/11/2001 11:14
[Re: Taym]
It sounds like more of a candidate for the first userland app to be called from the hijack menu, any takers ?
#45644 - 09/11/2001 11:46
v49: The Ultimate Empenguin Release
Well, I'm totally disappointed in all of you!
Ever since I introduced the Low/Medium/High VolAdj settings, nobody has bothered to point out that they all sound exactly the same! I mean, really! And you call yourselves beta testers! Hmmph.
The code has been there all along, it just never got invoked as near as I can tell. So Low/High were using the default (Medium) Vol\Adj parameters.
Anyway, while I was cleaning things up I noticed it and fixed it.
Announcing: v49: The Ultimate Empenguin Release
-- VolAdj Low & High actually work for the first time ever
-- turned off USER_DEBUG and FRAME_POINTER in the kernel config, saving memory
-- a few KB of dead IDE driver code now #if'd out for EMPEG, saving memory
-- the KNOB code in hijack is #if'd out for the Mk.1 kernel, saving memory
-- I think these kernels are now smaller than the stock v200v3 kernels
Edited by mlord (09/11/2001 11:56)
#45645 - 09/11/2001 12:01
Re: v49: The Ultimate Empenguin Release
Loc: England
I didn't think I could hear any difference or see any significant change in the multiplier value  . I should have more confidence in my observations and report them. Sorry  .
Excellent hacking btw. I'm really looking forward to future releases of this & any other hacks & apps you & others will develop. I wish I were better at programming so that I could help  .
Marcus
#45646 - 09/11/2001 13:14
I think there's a problem ....
V49
Mark I
Internal error: Oops: 0
CPU: 0
pc : [<796e6120>] lr : []
sp : c00f5ee4 ip : c00b21cc fp : 00000000
r10: 00000000 r9 : 00000038 r8 : 000000ec
r7 : 00000000 r6 : 00000000 r5 : c00c3f74 r4 : c00c3f74
r3 : 796e6120 r2 : 00000000 r1 : 000000ec r0 : c00c3f74
Flags: nzCv IRQs on FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process swapper (pid: 1, stackpage=c00f5000)
Stack:
c00f5f00: c005d21c
c00f5f20: 796e6120 20000013 ffffffff 00000000 c00c3f74 c00c3f34 00000000 c00c3fc4
c00f5f40: c005d5a4 c009e1e4 c00c3fc4 0000001c 00000000 00000164 c00c3f34 c00c3df8
c00f5f60: 00000001 00000000 c00c3dd0 c00f5f84 c005dd88 00000001 000000e1 00000004
c00f5f80: c005dea0 00000001 c00b7200 c009c764 c00bc4f8 c00a1650 c00bd184 4401a119
c00f5fa0: c0008580 c0059b2c c0059ff0 00000001 c0055db4 c005a00c c0041f14 00000001
c00f5fc0: c009c764 c00bc4f8 c00a1650 c0009954 c009c75c c0009a1c c00c3f34 c009c75c
c00f5fe0: c009c760 c009c984 c0009a24 c0009a1c c00c3f34 c009c75c c009c760 c000b424
Backtrace: no frame pointer
Code: pc not in code space
v48 didn't oops. But it did let me out. :)
#45647 - 09/11/2001 13:19
[Re: xavyer]
Exactly which of the kernels were you using when it Ooops'd.
Without knowing that, the data posted is worthless.
#45648 - 09/11/2001 13:24
Here is the filename:
v49.voladj.hijack.v200b3.mk1.zImage
You provide a link to only one kernel image for V49 and Mark I on your website.
Edited by xavyer (09/11/2001 13:36)
#45649 - 09/11/2001 13:38
[Re: xavyer]
I suppose it crashes immediately on boot, every time, right?
If so, then I think I see my misplaced #ifdef; affects the mk1 image only.
Right?
#45650 - 09/11/2001 13:41
Correct.
Oops'd 4 times out of 4 boot attempts.
Edited by xavyer (09/11/2001 13:45)
#45651 - 09/11/2001 15:05
[Re: xavyer]
V49
Mark I
Okay, I see what's wrong. Looks like I was just slightly too aggressive with the memory scrounging.
Mk2 players can have 1/2 drives, on a single ide controller.
Mk1 players have TWO ide controllers! Cool. Anyone got 4 drives in their Mk1 player yet?
v51 fixes this problem (v51 is identical to v50 for Mk2 players).
#45652 - 09/11/2001 15:22
Spiffy!! No Oops!
Uh, just to be clear about it, that would be:
V51
Mark I
HwRev: 04
v51.voladj.hijack.v200b3.mk1.zImage
No Oops.
Yet.
#45653 - 09/11/2001 15:38
[Re: xavyer]
>Spiffy!! No Oops! ... Yet.
Just try turning OFF the voladj while playing a tune.. v52 shortly.
#45654 - 09/11/2001 15:48
Yea, it got _much_ quieter .... but no oops.
Although, I got this showing up on minicom:
E !! mp3_decoder.cpp 1052: Failed to seek to offset 3751126, error=0xc0044000
E !! local_audio_component.cpp 1846: Invalid bitrate tag for FID 0xba0.
Which, i believe, doesn't have anything to do with the hijack stuff ....
#45655 - 09/11/2001 16:01
Don't think so  It's a bit short on space. Hmmm, the max height of the disks in a MkI is 19.5mm (according to riocar.org) and there are the 9.5mm disks... Even room for a layer of double sided tape!
Then there's the power supply issue - don't know if it could supply 4 disks...
I'm currently in the process of swapping disks, have a MkI with 10+18G, a MkIIa with a 10G and a loose 30G drive. Final config will be 10+10 in the MkI and 30+18 in the MkII, all data from the MkI transfered to the MkII.
Disk to disk copy is slower than I expected (no numbers tho)
#45656 - 09/11/2001 16:36
[Re: mtempsch]
Don't forget the empeg only has an ISA bus, which is going to be the limiting factor in drive to drive copies.
#45657 - 09/11/2001 16:42
[Re: andy]
Dopeslap! Of course...
And ISA is limited to something like 8MB/s, isn't it?
#45658 - 09/11/2001 21:39
[Re: mtempsch]
Well.. 8Mhz * 16-bits == 16MB/sec, if it could clock data every cycle.
In practice, the limit is about half that number, so you're right on.
But the current drive-to-drive copies are probably not even close to that.
Turn on IDE multmode and they'll get a LOT faster. I'm going to include multmode=8 as a standard setting in my next hijack kernels, as an experiment (oh ye guinea pigs..)..
#45659 - 09/11/2001 22:49
Loc: Southwest
Can you please elaborate on "a LOT faster" ? Will those speed-ups take effect from a console prompt using the cp command?
Thanks for all your great work. Wow this is an exciting way to develop! Thank you for the hacks!
#45660 - 09/11/2001 23:01
[Re: time]
Try it yourself, with any empeg kernel:
echo 'multcount:8' >/proc/ide/hda/settings
I'm just making that the power-on default in my new kernels.
#45661 - 10/11/2001 00:35
And the corresponding for hdb/hdc I presume?
Unfortunately, as I read your post, I'm already halfway through copying the fids from the 10G and the 18G was done during the night..
#45662 - 10/11/2001 10:57
Actually, it was the VERY FIRST thing I noticed. And I thought it was just a question of there being ver subtle differences in the variables. That's one reason I was asking for a "customizable" version that allowed me to edit the parameters. I thought I could improve upon it.
#45663 - 11/11/2001 00:55
Actually, you may yet get that wish. I'm looking at the IR stuff a little now, looking for a more convenient way to integrate multiple alternative IR codesets without folks having to get down and dirty. And the best approach I see is to dump them into the config.ini file and send it down with empode. Which means maybe the hijack driver will end up reading a file (config.ini) at some point, in which case.. customizeable menu items, voladj parms, etc..
But maybe I'll forget again by the time I return in December..
#45665 - 11/11/2001 15:11
Loc: Melbourne, Australia
Ahem. Truth be told, I noticed out in the last couple of days that two of the volume adjustment parameters (real and fake silence!!) were just being ignored in voladj_intinit. So even if you had been setting them, it wouldn't have done a skerrick of good. If anybody thinks they need them, and isn't set up to compile kernels, let me know. (I think this is unlikely, given that it's been that way for a looong time now and nobody has complained.)
Richard.
#45666 - 11/11/2001 17:33
Is there anyway to move the VolAdj setting off the front of the push button menu. I like it on low and usually never change it. But I like to get the other settings Volume, beep and Balance without having that in the way. So either an option to have it there or just in the menu would be nice. At least for me.
Sonic Blue 03 Cobra Vert Owner!!!
#45667 - 11/11/2001 20:13
[Re: 94cobra]
Well, for volume just spin the knob: no pushes required, no conflict with VolAdj.
And beep/balance are probably static settings for darn near everybody, 'cept maybe you. Or are there lots of other "per-song total readjustment" types out there?
Maybe I'll waste another bit of flash on it when I get back, which would also then allow a few other new choices.. but until then..
#45668 - 12/11/2001 01:30
[Re: rjlov]
Well, I don't know whether it's controlled by those parameters, but I have noticed that even at 'Low' setting the voladj amplifies very low-level noise in the 'silence' at the end of tracks to quite audible level.
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#45669 - 12/11/2001 03:31
Well it was just kinda annoying when using the volume and I would press the button(not nessesarly on purpose) and change the VolAdj setting when I really only wanter to change the volume.
#45670 - 12/11/2001 06:58
[Re: bonzi]
I've fixed the bug Richard pointed out, and lowered the setting for "Low" VolAdj in my latest hijack kernels. Maybe "Low" will behave better for you now.
