#47248 - 19/11/2001 20:57
Hijack v70: "long" presses fixed
Well, they weren't really broken on the standard remotes, but "long" IR button translations with .L should be working now in v70. After seeing reports of compatbility issues with v66, I looked harder at the code and found/fixed a timing error that affected the .L detection.
New in v70:
-- .L actually works in IR-translation macros
-- read/check temperature every 4sec instead of every 2sec.
-- fixed bug which caused unpredictable invocations of inittherm(),
it should now get called only about once every 5 minutes or so.
-- added a button-event counter to the "Button Codes Display" screen.
Any more bugs? Please make an extra special effort to thrash at this release over the next 16 hours or so, cuz after that you'll have to wait until (almost) Christmas for fixes from me.
Any Kiwi's in the crowd?
Cheers.
#47249 - 19/11/2001 21:01
Re: Hijack v70: "long" presses fixed
You da man! The long press works again on my Alpine remote. Just in time. I am on a long road trip tomorrow. About 12hrs.
P.S. Have a good trip.
Sonic Blue 03 Cobra Vert Owner!!!
#47250 - 19/11/2001 21:04
[Re: 94cobra]
>You da man!
Thanks for re-testing so quickly, Dude!
#47251 - 19/11/2001 21:18
Thats what I'm here for.
#47252 - 19/11/2001 23:00
Re: mlord question Any Kiwis in the crowd?
Yes,
We have at least one Kiwi here -
I'm a Kiwi - you going to be down this way then?
I live in Auckland as does JazBZ [or whatever his name is].
If you're going to Kiwiland then we can maybe catch up sometime - email me at number6@farsight.co.nz and we can set something up
[or just reply to this post]
I'm running V62 right now of the patched kernel but I'll have v70 by nightfall.
Regards
#47254 - 20/11/2001 04:24
Ok, so I confirm that the two buttons SOURCE and PAUSE on the Kenwood remote do not support logn press at all. It is clear in the IR code detection in HiJack. Now, I am going to reprogram one fo the other buttons and check if that works.
#47255 - 20/11/2001 09:19
[Re: number6]
Loc: NRW, Germany
Another Kiwi here  - living in Germany at the mo though.
#47256 - 20/11/2001 10:47
[Re: tonyc]
>if I define a press-and-hold sequence,
>it won't execute until I let go of the button
The way it works is, when you press the button, the translation waits to see if you are going to hold it for longer than one second. After one second, it says "aha! long press", and then sends the translation sequence of press/release codes, except for the final "release" code. When you let go of the button, the final "release" code is then sent. I figured that this might be more useful to people, but that was just my guess.
I can change this behaviour, and simplify the code in the process, if we all agree on it. It's actually more complex to implement the current behaviour than the alternative you seem to want.
#47258 - 20/11/2001 11:22
[Re: tonyc]
>I'm just used to the way it works on the Rio remote
But.. but.. that's exactly the same way the translations do it!
(or at least that is how the code is supposed to be doing it).
Perhaps here it's just a matter of the particular player function responding differently? Try programming an alternative longpress to do exactly what an existing Rio longpress does.. same behaviour?
If the translator were to NOT hang onto the release code until the user lets go, then how the heck could anyone map buttons to do "fast forward" or "fast reverse" ??
Regardless, I'll add something to change the behaviour for some situations.
Perhaps a .I modifier on the macro definition might do it?
#47259 - 20/11/2001 11:28
Oh, wait.. I get it (at last they say!).
The issue here I suppose is that macros which don't end in .L are effectively being forced into .L. Right? Got it.
This is an artifact from before we had .L capability on the right of the equal sign.
Okay, now that I finally see the real issue, I can fix it.
Thanks all!
#47261 - 20/11/2001 13:09
[Re: tonyc]
>When I hold down the button, my Empeg doesn't go to standby until I release it.
>I agree that for FF/REW, it makes sense to hold onto the release code.
>So maybe it should be configurable with a modifier as you have stated.
Okay try v72 and see if it works better for you.
For the case where you end a macro with a .L button, but don't want it to hang around for the final button release (ala FF/REW), then just add another "dummy" button press to the end of the macro. Specifically, 0xffffffff can be used as a "dummy" press (it is never passed on).
Okay?
#47263 - 20/11/2001 13:41
[Re: tonyc]
>The press-and-hold functions like FF and REW aren't working as they should.
>Holding them down acts like a "tap" so it goes to the next track
>instead of fast-forwarding, for instance.
I'll bet you have defined them in the wrong sequence in config.ini:
The .L translations must preceed the non .L translations..
I had the same error in my config.ini file until a few minutes ago,
and it really confused the heck out of me while testing..
#47265 - 20/11/2001 13:56
[Re: tonyc]
Yes, it will be exactly 2sec, a side effect of implementing your previous request.
Unavoidable, too, with the RIO codes.
But.. if you use the Kenwood codes for FF/REW, these will work without the dummy code, as in:
AD5242.LM=b9460c.L ;Rewind
AD5243.LM=b9460b.L ;Fast Forward
AD5242.M=20df10 ; Prev Track
AD5243.M=20df11 ; Next Track
Edited by mlord (20/11/2001 13:58)
#47266 - 20/11/2001 14:05
Ooopps I goofed on the FF code, here are the correct codes:
AD5243.LM=b9460d.L ;Fast Forward
#47268 - 20/11/2001 14:24
[Re: tonyc]
Yeah. I'm going to revert the behaviour back to what it was before.
If you want a longpress to release without waiting for the actual button release, just append a ffffffff code to the tail end of the macro, as in:
xxxxxx=yyyyyyy.L,ffffffff
Okay?
#47269 - 20/11/2001 14:31
Hijack v73
Okay, v73 is out, with some minor IR translation changes and other fixes.
Please read the ir_translate notes on my website for exact details (and examples).
http://rtr.ca/empeg/
Have a great next 3 weeks, everyone.
byebye..
#47270 - 20/11/2001 21:05
Re: Hijack v73
I don't know what's scarier... The fact that Mark has been posting and updating all the way to the last minute.... Or the fact that if he didn't go on vacation, he could probably double the amount of work he's already done on this project. :) Seriously, go back and look at the release history as it's been posted here. He's a machine!
I hope the vacation gives you a much deserved break. But if you feel some inspiration for a revolutionary new feature while on that 5.13b, don't forget to chalk-up, whip out a pencil and jot it down. :)
#47271 - 20/11/2001 21:11
Re: Hijack v73
[Re: hybrid8]
Loc: Texas
I tried v66 (have not tried v71 yet). I received an error when syncing the config file (timed out)
Had the following as a test:
[ir_translate]
00aa550f=0020DF12
What did I do wrong?
#47272 - 20/11/2001 21:43
Re: Hijack v73
[Re: blitz]
[ir_translate]
00aa550f=0020DF12
Probably nothing. Try it again (maybe the empeg decided to do a filesystem check that time..)
#47273 - 20/11/2001 21:50
Re: Hijack v73
for Christs sake pack for the trip or something! You're getting me nervous.
Murray
Is it the 'N', or the 'Zero'?
#47274 - 20/11/2001 22:42
[Re: tonyc]
The Alpine is that way.
#47275 - 21/11/2001 11:18
Loc: San Jose, CA
Mlord is probably gone, but I want to report that when you're in the equalizer screen, and you tap the knob, it brings up the VolAdj. Oops. You don't want that to pop up in the EQ.
Calvin
#47277 - 30/11/2001 07:13
Re: Possible Hijack Bug
[Re: tonyc]
It would make sense if it did from mlord's point of view as he uses it to exit any of his menus.
