#93112 - 11/05/2002 21:03 Drive Trouble
Tyris
Loc: Texas, USA
Well, I just had some installation work done on my car, and now my Empeg takes a very long time to load. It sits at the "Loading music databases..." part for a long time.
I connected to the player with HyperTerminal, and while it's loading the music databases, it shows messages like this:
hda: irq timeout: status=0xd0
ide0: reset: success
end_request: I/O error, dev 03:03 (hda), sector 4116
hda: status timeout: status=0xd0
hda: drive not ready for command
Any ideas?
Tyris
MkIIa 10gb Blue - 040103702
#93113 - 11/05/2002 21:06 More messages [Re: Tyris]
Tyris
Loc: Texas, USA
I'm also getting this message:
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 2809
056, error=0xc0044000
Tyris
#93114 - 11/05/2002 21:53 Re: More messages [Re: Tyris]
The "Failed to find valid sync after seeking to offset" error is not really an error. I think it might be something to do with VBR files being hard to seek on. Anyways I see it all the time and there aren't any problems with the unit. Look here.
As for the irq timeout problem, then you have problems. Have you replaced the drive cable yet? If not click here...
#93115 - 11/05/2002 22:38 Re: More messages [Re: Shonky]
Tyris
Loc: Texas, USA
Well, I haven't replaced the cable, but I'm not sure that it's really the cable. It shows the I/O error message that I posted above for the same three sectors (4114, 4116, 4118) everytime. It does eventually finish loading, but it just takes a lot longer than it should.
Tyris
#93116 - 11/05/2002 22:59 Re: More messages [Re: Tyris]
Possibly a dodgy couple of sectors then. Have you tried fscking it like this?
#93117 - 12/05/2002 00:34 Re: More messages [Re: Shonky]
Tyris
Loc: Texas, USA
I tried the fsck procedure in the FAQ entry you linked to, and fsck didn't find anything wrong with the drive. However, the problem is still there.
Tyris
#93118 - 12/05/2002 03:17 Re: More messages [Re: Tyris]
Sectors 411x probably aren't part of the music partition. hda4 is the big music partition but there are 4 others, one of which probably contain that sector. I'm not sure whether fdisk is on the empeg but it should tell you which partition has those sectors.
According to my fdisk, you're probably looking at hda5 which is the root partition. You can't fsck a mounted drive and I don't know how you can check it. Does someone else know?
#93119 - 12/05/2002 07:59 Re: More messages [Re: Shonky]
No problem at all to fsck a READ-ONLY mounted drive. Just do it. How do ya think the root partition ever gets checked on any system?
Just reboot afterwards to ensure no confusion (not necessary with newer Linux kernels, but on the Empeg..).
#93120 - 12/05/2002 09:52 Re: More messages [Re: Shonky]
Tyris
Loc: Texas, USA
Well, I'm pretty sure that I fscked the root partition when I followed the FAQ entry you linked to. That didn't report any errors.
Tyris
#93121 - 12/05/2002 13:04 Re: More messages [Re: Tyris]
David
Loc: Cambridge
Could you post the full boot log please?
#93122 - 12/05/2002 16:26 Re: More messages [Re: mlord]
True. But in the case of an empeg how do you fsck to fix it if something is wrong?
#93123 - 12/05/2002 16:33 Re: More messages [Re: Tyris]
Correct again, if you followed that FAQ entry to the letter you did fsck the root partition. I was looking for the fsck /dev/hda5 and completely skipped over the fsck /. I always though you had to specify the device name and not just the mount point.
I'm going to hide in the corner now.
#93124 - 12/05/2002 18:12 Re: More messages [Re: David]
Tyris
Loc: Texas, USA
Here it is:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com):Wed May 2
If there is anyone present who wants to upgrade the flash, let them speak now,ready mounted)
SA1100 serial driver version 4.27 with no seri
Remounting
or forever hold their peace...it seems not. Let fly the Penguins of Linux!emounting second music partition read-onlyRT
e000 v1.04No seconda
Copying kernel...(irq = 17) is a
Calling linux kernel... development mode. You
Uncompressing Linux....................................... done, booting the ker
Sign
player 206f69
khttpd: listening on port 80
nel.empe
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v266 (root@tbird.localnet) (gcc vecpp : 385:empeg-car 2.00-beta11 2002/02/08.
em
rsion 2.95.3 20010315 (release)) #2 Fri May 3 20:44:54 EDT 2002sed, CS4231A revision a0
Processor: Intel StrongARM
ide0 at 0x000-0x007,0x038 on irq
hda: FUJITSU MHM2100AT, 9590MB
IP Protocols: ICMP, UDP, TCP63
TCP: Hash tables configured (ehash 16384 bhash 16384)r initialized
smc chip
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)c9194.c:v0.12 03/06/96 by Erik Stahlman (erik@v
Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 )9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:0
6
Partition check:
hda: hda1 < hda5 hda6 > hda2
Starting kswapd v 1.5
RAMDISK: Loading 320 blocks [1 disk] int
VFS: Mounted root
empeg dsp mixer initialisedg proc
Mounti
empeg dsp initialisedon
empeg audio-in initialised, CS4231A revision a0 but got error 19
empeg remote control/panel button initialised.artition
Tried
Error
empeg state support initialised 0089/88c1 (save to d0005680).
Remounting first music p
empeg RDS driver initialised
empeg power-pic driver initialised (
hda: FUJITSU MHM2100AT, ATA DISK drivecoder.cpp :1049:Failed to find valid
hda: FUJITSU MHM2100AT, ATA DISK drive3, error=0xc0044000
hda: FUJITSU MHM2100AT, ATA DISK drive6 (hugo@empeg.com)
hda: FUJITSU MHM2100AT, ATA DISK drivee is anyone present who wants to upgra
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63r peace...it seems not. Let fly the Penguins of Linux!
smc chip id/revision 0x3349Copying kernel...
6
Partition check:
hda:hda: set_geom(16383,16,63)10315 (release)) #7 Fri Feb 8 1
hda1 < hda5 hda6 > hda2 hda3 hda4
RAMDISK: ext2 filesystem found at block 0vision 11
RAMDISK: Loading 320 blocks [1 disk] into ram disk... done.98 Corel Computer Corp.
VFS: Mounted root (ext2 filesystem).mpeg-car player (hardware revision 9
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Trying to unmount old root ... okayry: 15024k/16M available (964k code
Freeing unused kernel memory
Mounting proc
Mounting first music partitiones: 16384 (order 4, 64k)
Tried to mount /dev/hda4 as reiserfs but got error 19ache hash table entries: 4096 (order 2, 16k)
POSIX conformance tes
Linux NET4.0 for Linux 2.2
Error mounting partitions (possibly already mounted)omputer Society NET3.039
Remounting first music partition read-only/IP 1.0 for NET4.0
No secondary hard diskash 16384)
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStartingBrattli)
playervision:
kftpd: listening on port 21
end_request: I/O error, dev 03:03 (hda), sector 4114
end_request: I/O error, dev 03:03 (hda), sector 4118
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 3271
882, error=0xc0044000
Tyris
#93125 - 12/05/2002 18:19 Re: More messages [Re: Tyris]
The top of your log is really wacky. It looks like half of it is from a previous boot???
- Trevor
#93126 - 12/05/2002 19:32 Re: More messages [Re: tman]
Tyris
Loc: Texas, USA
Nope, I don't think so... I started a new session, so it should only be one. I'm not too sure why some letters are cut off though... I used 115200, 8, N, 1, no flow control.
Tyris
#93127 - 13/05/2002 05:43 Re: More messages [Re: Tyris]
Your settings are fine. However which program are you using for serial comms? It looks like you are getting (well not getting) quite a few lost characters. I am not a believer in Hyperterminal and I never will be. Try something like CRT/SecureCRT. They're not free but are tons better.
Any halfway decent PC should be able to keep up with the flow rate which tends to suggest to me that the software is at fault.
I have seen others post logs like these before so your not the only one with this problem.
#93128 - 13/05/2002 06:51 Re: More messages [Re: Shonky]
Hyperterminal on Windows 2000 simply does not work. In NT it was OK. Don't know about the non-NT versions.
I use Tera Term Pro, which is free and is tons better than Hyperterminal.
#93129 - 13/05/2002 15:10 Re: More messages [Re: Shonky]
Tyris
Loc: Texas, USA
Here's the CRT version:
e000 v1.04
Copying kernel...
Uncompressing Linux....................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v266 (root@tbird.localnet) (gcc version 2.95.3 20010315 (release)) #2 Fri May 3 20:44:54 EDT 2002
empeg-car player (hardware revision 9, serial number 40103702)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg state support initialised 0089/88c1 (save to d0005b80).
empeg single channel IDE
Probing primary interface...
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0e:76
Partition check:
Press Ctrl-A to enter pump...•Ô•j½Õ¹Ñ•‘É½½Ñ¡•áÑɁ™¥±•ÍåÍÑ•µ¥É•…‘½¹±å¹)5ÿchange_root: old root has d_count=1
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To ComStarting player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Vcb: 0x4086d000
Tyris
#93130 - 14/05/2002 04:20 Re: More messages [Re: Tyris]
Tyris
Loc: Texas, USA
Hmm... Well, do I need to format the drive and start over, or is there something else I can do to fix this?
Thanks!
Tyris
#93131 - 14/05/2002 04:29 Re: More messages [Re: Tyris]
IRQ errors like that are really the sign of a bad cable. Please check this link for more info...
Edited by pgrzelak (14/05/2002 04:30)
