Well I followed that list of commands and after the SYNC command I unplugged the power cord and cycled power but I still can't synchronize. Here's a paste of the serial log after I first started up. For some reason, in Hyperterminal when i scrolls up beyond the screen the text gets garbled somewhat so hopefully you can see something in this:
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v335 (root@ibbm) (gcc version 2.95r pump...VFS: Mounted
Linux NET4.0 for Linux 2.2donly.
Based
.3 20010315 (release)) #2 Tue May 13 15:01:19 EDT 2003_root: old root has d_count=1
NET
Processor: Intel StrongARM-1100 revision 11ay
IP Protocols: ICMP, UDP
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.84 bhash 16384)
Ir
empeg-car player (hardware revision 9, serial number 30103111)usic partition
IrCOMM protocol (Dag Brattli) /d
Command line: mem=16mt go
Starting kswapd
IrCOMM protocol (Dag Brattli)D12 id 1012
Starting kswapd v 1.5
empeg state support
player.
empeg RDS driver initialis
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTiver initialised (first boot)empeg car - 2.1434
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTialized: 16 RAM disks of 4096K sizeisk.cpp
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTg single channel IDE
Pro
Signature is 206f6972 'rio 'fsck 1.19, 13-Jul-2000 f
hda
Found custom animation at offset 0x9a38c
hdb: FU
Tuner: loopback=0, ID=-1 drivedirectory while de
empeg display initialised.t 0x000-0x007,0x038 on irq
empeg dsp audio initialised
hda: FUJITSU MHL23
empeg dsp mixer initialised, CHS=58140/16/63oved menu
empeg dsp initialised
empeg audio-in initialised, CS4231A revision a08kB Cache, CH
Remounting first music
Probing primary interface...
You don't exist. Go away.
R
hda: FUJITSU MHL2300AT, ATA DISK driveo ram disk... done.
hdb: FUJITSU MHL2300AT, ATA DISK drive
empeg-pump v0.03 (19980601) -a:
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63 root (ext2 fil
Mounting first
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2 but got error 19: Force fsck on reboot.
Mounting
7c
Partition check:on -n:
hda: hda1 < hda5 hda6 > hda2 hda3 hda4 partition read-only
hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4d music partition read-onlyc: canc
RAMDISK: ext2 filesystem found at block 0now to go into development mode. You Have
Starting player
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To Comply.þStar
ting player
Hijack: intercepting config.ini
hijack_exec("/usr/local/bin/emphatic"), rc=0 (okay)
hijack: removed menu entry: "Hard Disk Detection"
khttpd: listening on port 80
kftpd: listening on port 21
opening display...
Using non-standard cache size 86 (adjustment 48)
starting notify thread...
notify thread started (tid=1026)...
lyrics thread started (tid=2051)...
emphatic v1.10 (built Feb 18 2003 20:15:18) running as pid 11
Vcb: 0x4056d000
And then this is when I synchronize:
Adding Swap: 16596k swap-space (priority -2)
disk.cpp : 876:Couldn't cleanly unmount drive 0 (c0041010)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
hijack: removed menu entry: "emphatic"
Restored terminal settings
Restart code received
Starting player
opening display...
emphatic v1.10 (built Feb 18 2003 20:15:18) running as pid 55
Hope this helps.
One of the last MK2's from SonicBlue... Blue/60gig S/N: 030103111
