Loc: Sunnyvale, CA, USA
Great idea! One suggestion: we should start with the same set of WAV files to eliminate errors introduced by bad rips (unless you want to compare ripping utilities but that's an orthogonal issue). Also, you can't mandate a specific VBR setting since every encoder has a different scale (e.g. LAME uses a 0-9 scale).
