Much of the stuff that can go wrong is already known, and thus far I haven't had too much trouble tracing signals. What's the problem/symptoms with your unit?
EDIT: Oh, is this the infamous display cable experiment unit?
Perhaps it just needs the whole display cable assembly replaced -- have you been recrimping onto the existing header on the displayboard, or did you already replace (desolder, remove, resolder new one) on the displayboard end of the cable?
Edited by mlord (15/03/2004 15:14)
