#219321 - 22/06/200410:32Re: hard drive shot by interrupted synch?
[Re: bjoern]
tfabris carpal tunnel
Before assuming the drive is bad, make absolutely sure that your disk drive problem isn't one of the other things in the FAQ. There is a long list of possible causes there, be sure to carefully check each and every one of them. Go through the list methodically and don't just assume "oh that can't be the problem."
