#279282 - 26/04/200611:44Re: Hijack v454: Doh! might even work for SaveAux/RestoreSrc & waking
[Re: jarob10]
Quote: You are right it is ambiguous, so I checked my CK-7W with an avo. The mute line is normally floating, then switches to ground when a call is made.
I had to use a pull-up resistor (hacked into the CK-7W harness) to get the empeg to recognise an incoming call.
Cool. But note that my CK-7W is working great without this mod. The 'Sense' section of the config.ini on my player contains this:
